请求大家帮忙翻译?
请求大家帮忙翻译:谢谢 1、The physical properties of the cold fluid have been extrapolated beyond the valid temperature range. Check calculated values. 2、Thermosiphon instability calculations indicate that the system is stable. No instability threshold was found. 3、Setting plan error: Axial nozzle location is not supported by setting plan calculation code. 显示全部
0人参与回答
