模拟洗油泵?
软件初涉者,求助各位,谢谢。 如题,模拟洗油泵,物料甲基奈、芴、苊,模型pump,物性方法ideal,出现如下提示: ->Processing input specifications ... * WARNING IN THE "PROPERTIES" PARAGRAPH WHICH BEGINS ON LINE 58 FREE-WATER METHOD SHOULD BE STEAMNBS WHEN THE MAIN PROPERTY METHOD IS SRK. DEFAULT FREE-WATER METHOD IS STEAM-TA PLEASE SPECIFY THE RECOMMENDED FREE-WATER METHOD AND RUN AGAIN. THE PAIR PARAMETERS FOR ELECNRTL OPTION SET HAS BEEN RETRIEVED FROM DATABANK ENRTL-RK. ** ERROR IN PHYSICAL PROPERTY SYSTEM EQUATION OF STATE MODEL POLYPCSF HAS MISSING PARAMETERS: PCSFTM (DATA SET 1) MISSING FOR COMPONENT C11H1-01 ** ERROR IN PHYSICAL PROPERTY SYSTEM PCSFTU (DATA SET 1) MISSING FOR COMPONENT C11H1-01 ** ERROR IN PHYSICAL PROPERTY SYSTEM PCSFTV (DATA SET 1) MISSING FOR COMPONENT C11H1-01 ** ERROR IN PHYSICAL PROPERTY SYSTEM PCSFTM (DATA SET 1) MISSING FOR COMPONENT C11H10 ** ERROR IN PHYSICAL PROPERTY SYSTEM PCSFTU (DATA SET 1) MISSING FOR COMPONENT C11H10 ** ERROR IN PHYSICAL PROPERTY SYSTEM PCSFTV (DATA SET 1) MISSING FOR COMPONENT C11H10 ** ERROR IN PHYSICAL PROPERTY SYSTEM PCSFTM (DATA SET 1) MISSING FOR COMPONENT C11H1-02 ** ERROR IN PHYSICAL PROPERTY SYSTEM PCSFTU (DATA SET 1) MISSING FOR COMPONENT C11H1-02 ** ERROR IN PHYSICAL PROPERTY SYSTEM PCSFTV (DATA SET 1) MISSING FOR COMPONENT C11H1-02 ** ERROR IN PHYSICAL PROPERTY SYSTEM PCSFTM (DATA SET 1) MISSING FOR COMPONENT C13H1-01 ** ERROR IN PHYSICAL PROPERTY SYSTEM PCSFTU (DATA SET 1) MISSING FOR COMPONENT C13H1-01 ** ERROR IN PHYSICAL PROPERTY SYSTEM PCSFTV (DATA SET 1) MISSING FOR COMPONENT C13H1-01 ** ERROR IN PHYSICAL PROPERTY SYSTEM PCSFTM (DATA SET 1) MISSING FOR COMPONENT C12H1-01 ** ERROR IN PHYSICAL PROPERTY SYSTEM PCSFTU (DATA SET 1) MISSING FOR COMPONENT C12H1-01 ** ERROR IN PHYSICAL PROPERTY SYSTEM PCSFTV (DATA SET 1) MISSING FOR COMPONENT C12H1-01 ****PROPERTY PARAMETER ERROR EQUATION OF STATE MODEL POLYPCSF HAS MISSING PARAMETERS ! Calculations stopped because of missing property parameters 显示全部
3人参与回答
,给排水工程师 2018-05-23回答
很多物质缺失物性啊呵呵,建议把模型上传一下这样比较好分析。。。
,销售 2018-05-23回答
,电气/仪表工程师 2018-05-23回答
软件初涉者,求助各位,谢谢。 如题,模拟洗油泵,物料甲基奈、芴、苊,模型pump,物性方法ideal,出现如下提示: - processing input specifications ... * warning in the "properties" pa...
