The Client shall ensure that the Contractor is named as additionalinsured on any insurance policies maintained by Client with respect to theProject for which the Services are being performed and the property where theProject is located or with respect to which the Services are provided, or thatsuch policies contain a waiver of subrogation against the Contractor, itssub-contractors, and their officers, directors, shareholders, agents andemployees.
install the actuator so that the piston is in the cylinder end position at housing side 安装执行机构以使活塞处于缸体(筒体)位于机壳一侧的末端位置 housing 外壳, 例如: the outer mechanical seal shall be located in a recessed housing outside the main flow path of the pump to avoid damage. 外置机械式密封应该位于泵主流道以外的凹式箱体内,以避免受到破坏。
