1.Heat, as a form of energy, cannot be created or destroyed. Heat can be transferred from one substance to another. 是老师布置的作业吧? 第一条翻译参阅“能量守恒定律”: 能量既不会凭空产生,也不会凭空消失,它只能从一种形式 转化 为别的形式,或者从一个物体转移到别的物体,在转化或转移的过程中其总量不变。
4. all commissioning operations have been completed, including pressure leaks check, blinds removal, drying and nitrogen purge of equipment and piping interested by process fluids (venting nitrogen pressure to blow down through psv's by pass and through the drain on the lowest points, pipes and equipment). 为了加分试译: 所有试车已经完成,包括:带压渗漏检测,去除盲板,干燥并用氮气吹扫与工艺流体有关的设备和管线(通过吹扫压力安全阀的支路及最低点、管线和设备上的排出口来排除氮气释放压力。)
2# bamboobamboo 2:yields: ethylene yields to 84% for ethane, 38% for naphtha and 30% for gas oil may be achieved depending upon feedstock characteristics. ( yield--- 收率 ethane -乙烷 gas oil -柴油 naphtha -石脑油) 产率:根据进料的不同,乙烯的产率不同,由乙烷生产产率可以达到84%;由石脑油生产产率可以达到38%;由汽油生产可以达到30%。 3 : vent the exchanger to the atmosphere with the globe valve open on the line. ( vent--- 放空; globe valve -球阀) 通过管线上的球心阀可以将换热器排空到大气环境中。
2:yields: ethylene yields to 84% for ethane, 38% for naphtha and 30% for gas oil may be achieved depending upon feedstock characteristics. 产率:以乙烷为原料,乙烯产率为84%;若以石脑油或瓦斯油为原料,视原料性质乙烯产率可分别达到38%和30%。 3:vent the exchanger to the atmosphere with the globe valve open on the line.(vent---放空;globe valve-球阀) 开启管线上的球阀,将换热器放空至大气。
1. heat, as a form of energy, cannot be created or destroyed. heat can be transferred from one substance to another. 热,作为能量的一种形式,既不能被创生也不能被消灭。热可以从一个物体转换到另一个物体。
4. all commissioning operations have been completed, including pressure leaks check, blinds removal, drying and nitrogen purge of equipment and piping interested by process fluids ( venting nitrogen press ure to blow down through psv's by pass and through the drain on the lowest points, pipes and equipment ). 注意标红部分的修饰关系,另外注意中文里的顿号运用: 4. 所有试车操作均已完成,包括工艺流体相关设备与管线的压力试漏、盲板拆除、干燥以及氮气吹扫(通过安全阀旁路以及低点、管线与设备上的排凝口泄放,来放掉氮气压力)。 -----------------------------------------fyi
(venting nitrogen pressure to blow down through psv's by pass and through the drain on the lowest points, pipes and equipment). (通过压力安全阀的旁路排放以及管线/设备上的低点放净进行氮气泄压。)
