阀门英汉对照?
Air valves 空气阀门 Angle Stop valves 角式截止阀 Angle Throttle Valves 角式节流阀 Angle Type Globe Valves 门角式截止阀 Ash valves 排灰阀 Aspirating valves 吸(抽)气阀 Auxiliary valves 辅助(副)阀 Balance valves 平衡阀 Bellows valves 波纹管阀 Blowdown valves 泄料(放空,排污)阀 Brake valves 制动阀 Butterfly Type Non-slam Check 蝶式缓冲止回阀 Butterfly Valves with Gear Actuator 蜗轮传动蝶阀 Buttwelding valves 对焊连接阀 Clamp valves 对夹式阀门 Cock 二通 Combination valves 组合阀 CQ Thread Ball Valves CQ螺纹球阀 Culvert valves 地下管道阀 Deceleration valves 减速阀 Diaphragm Valves 隔膜阀 Decompression valves 泄压阀 Double Disc Flat Gate Valves 双闸板平板闸阀 Double Disk Parallel Gate Valves明杆平行式双闸板闸板 Double Opening Exhaust Valves 双口排气球 Drainage valves 排水阀 Electric Actuated Stop Valves 电动截止阀 Electric Actuated Wedge Gate Valves电动楔式闸阀 Electric Double Disk Parallel Gate Valves电动平行式双闸板闸板 Emergeny Cut-off Valves 紧急切断阀 Exhaust valves 排气阀 Free Float Type Steam Trap 浮球式疏水阀 Flange Ball Valves 法兰球阀 Flange Gate Valves 法兰闸阀 Flange Globe Valves 法兰截止阀 Gauge Valves 仪表阀 Hand-operated valves 手动阀 Hard Seal Butterfly Valves 金属密封碟阀 High Temperature Pressure Power Station Gate Valves 高温高压电站闸阀 High Temperature Pressure Power Station Globe Valves 高温高压电站截止阀 Hydraulic relay valves 液压继动阀 Lift Check Valves 升降式止回阀 Lift Check Valves 升降式止回阀 Limit valves 限位阀 Lining Ball Valves 衬里球阀 Lining Butterfly Valves 衬里碟阀 Lining Check Valves 衬里止回阀 Lining Cock 衬里二通 Lining Globe Valves 衬里截止阀 Lining T-Cock Valves 衬里三通旋塞阀 Liquid Indicator 液位计 LPG Pipe Fitting 液化气管件 Magnetic Co-operate Globe Valves磁耦合截止阀 Magnetism Forle Pumps 磁力泵 Manual Oil Pumps Valves 手摇油泵(阀 ) Meter Needle Type Globe Valves 仪表针形截止阀 Oblique Stop Valves 直流式截止阀 Parallel Slide Valves 浆液阀 Pintle valve 针形阀 Piping Centrifugal Pumps 管道离心泵 Plunger valves 柱塞阀 Pressure valve 压力(増压)阀 Piping Pumps 管道泵 Piping Safety Valves 管道安全阀 Plunger Globe Valves 柱塞截止阀 Quick Draining Valves 快速排污阀 Restrictor Valves 过流阀(或节流阀 ) Safety Valves 安全阀 Screw Pumps 螺杆泵 Scum Gate Valves 排渣闸阀 Solenoid valves 电磁阀 Single Disc Flat Gate Valves 单闸板平板闸阀 Single Opening Exhaust Valves 单口排气球 Slurry Pumps 泥浆泵 Stop Valves 截止阀 Strainer 过滤器 Submerged Motor Pumps 潜水电泵(排污泵 ) Swing Check Valves 旋启式止回阀 Swing Check Valves 旋启式止回阀 Tank Lorry Ball Valves 槽车球阀 T-Cock 三通 Thin Gate Valves 薄型闸阀 Throttle Valves 节流阀 Tiny Drag Slow Shut Check Valves 微阻缓闭止回阀 Triple (tee) valves 三通阀 Two-way valves 二通阀 Under Water Pumps 液下泵 Vacuum Pumps 水力喷射器(真空泵 ) Vertical Lift Check Valves 立式止回阀 Wafer Check Valves 对夹式止回阀 Wafer plate valves 对夹蝶板阀 Wafer Type Butterfly Valves with Rubber Itning对夹式衬胶蝶阀 Waste Valves 排污箱(阀 ) Water Seal Gate Valves 水封闸阀 Wedge Gate Valves 楔式闸阀 Y Type and Cylinder Filters Y型筒型过滤器 阀门零部件英汉术语对照 Axis Guide 轴套 Ball 球、球芯 Ball seat 密封圈 Blowdown Sealing Face 启、阀件密封面 Body 阀体 Bonnet 阀盖 Disc 阀瓣 Mut 螺母 Screw 螺栓 Sealing 密封件 Spring 弹簧 Stem 阀杆 Stem Mut 阀杆螺母 Stem seal 填料 Wedge Disc 闸板 阀门规范技术英语术语对照 Applicable medium 适用介质 Applicable temperature 适用温度 Butt Clamp 对夹 Chemical analysis 化学成份 Connecting format 连接形式 Double disc 双闸板 Flexible disc 弹性闸板 Flange 法兰 Hoop 卡箍 Inside thread 内螺纹 Jacket 夹套 Mains 电源 Material chemical analysis and mechanical capacity材料化学成份和机械性能 materials 材料 Materials for main parts 主要零件材料 Mechanical capacity 机械性能 Max. Discharging Capacity 最大排水量 Max. Operating Temperature 最高工作温度 Max. Allowable Temperature 最高允许温度 Max. Allowable Pressure 最高允许压力 Model 型号 Name of parts 零件名称 nitrogen (N) 氮 Nominal bore 公称通径 Nominal Pressure 公称压力 Nozzle 排气口 Outside thread 外螺纹 Oxidant 氧化性介质 Parallel 平行 Piping 管路 Piston 活塞 Reductant 还原性介质 Rising stem 明杆 Seal 阀座,密封面 Seat testing pressure 压力气密封试验压力 Socket 卡套 Specifications 性能规范 Single disc 单闸板 Solid 刚性 Strengh testing pressure 强度试验压力 Steam , condensate 蒸汽,凝结水 Stroke 冲程,行程 Water,oil,steam 水,温度,气 Wedge 楔式 Welding 焊接 阀门材质术语英汉对照 Atbas metal 镍铬钢 Buna-N rubber 丁晴橡胶 Casting aluminium brass 铸铝黄铜 Casting aluminium bronze 铸铝青铜 Ceramic metal 陶瓷金属 Chromel alloy 镍铬合金 CHR rubber 氯晴橡胶 Chrominm-molybdenum-vanadium steel 铬钼钒钢 Chromium stainless steel 铬不锈钢 Chromium-molybdenum steel 铬钼钢 Corrugation pad 波形垫 Cuprum alloy 铜合金 Ductile Cast iron 球墨铸铁 Expanded graphite 柔性石墨 Fine Steel Casting iron 优质碳素钢 Fluorous rubber 氟橡胶 Gray Cast iron 灰铸铁 Haynes alloy 钴铬钨合金 High tem perature steel 高温钢 Monel 蒙乃尔合金 Low temperature steel 低温钢 Nylon 尼龙塑料 Polytetrafluoroethylene(PTEF) 聚四氟乙烯 Polythene 聚乙烯 Pure aluminium 纯铝 Pure cupper 纯铜 Rubber graphite board 橡胶石墨板 Spring steel 弹簧钢 Stainless acid-resisting steel 不锈耐酸钢 Stainless and Graphite 不锈钢/石墨 Stainless steel 不锈钢 Steel Casting iron 碳素钢铸件 Shell Test Pressure 壳体试验压力 Service Fluid 工作介质 显示全部
angle stop valves 角式截止阀 manual oil pumps valves 手摇油泵(阀) angle throttle valves 角式节流阀 meter needle type globe valves 仪表针形截止阀 angle type globe valves 角式截止阀 oblique stop valves 直流式截止阀 butterfly type non-slam check 蝶式缓冲止回阀 parallesl slide valves 浆液阀 butterfly valves with gear actuator 蜗轮传动蝶阀 piping centrifugal pumps 管道离心泵 cock 二通 piping pumps 管道泵 cq thread ball valves cq螺纹球阀 piping safety valves 管道安全阀 diaphragm valves 隔膜阀 plunger globe valves 柱塞截止阀 double disc flat gate valves 双闸板平板闸阀 quick draining valves 快速排污阀 double disk parallel gate valves 明杆平行式双闸板闸板 restrictor valves 过流阀(或节流阀) double opening exhaust valves 双口排气球 safety valves 安全阀 electric actuated stop valves 电动截止阀 screw pumps 螺杆泵 electric actuated wedge gate valves 电动楔式闸阀 scum gate valves 排渣闸阀 electric double disk parallel gate valves 电动平行式双闸板闸板 single disc flat gate valves 单闸板平板闸阀 emergeny cut-off valves 紧急切断阀 single opening exhaust valves 单口排气球 free float type steam trap 浮球式疏水阀 slurry pumps 泥浆泵 flange ball valves 法兰球阀 stop valves 截止阀 flange gate valves 法兰闸阀 strainer 过滤器 flange globe valves 法兰截止阀 submerged motor pumps 潜水电泵(排污泵) gauge valves 仪表阀 swing check valves 旋启式止回阀 hard seal butterfly valves 金属密封碟阀 swing check valves 旋启式止回阀 high temperature pressure power station gate valves 高温高压电站闸阀 tank lorry ball valves 槽车球阀 high temperature pressure power station globe valves 高温高压电站截止阀 t-cock 三通 lift check valves 升降式止回阀 thin gate valves 薄型闸阀 lift check valves 升降式止回阀 throttle valves 节流阀 lining ball valves 衬里球阀 tiny drag slow shut check valves 微阻缓闭止回阀 lining butterfly valves 衬里碟阀 under water pumps 液下泵 lining check valves 衬里止回阀 vacuum pumps 水力喷射器(真空泵) lining cock 衬里二通 vertical lift check valves 立式止回阀 lining globe valves 衬里截止阀 wafer check valves 对夹式止回阀 lining t-cock valves 衬里三通旋塞阀 wafer type butterfly valves with rubber itning 对夹式衬胶蝶阀 liquid indicator 液位计 waste valves 排污箱(阀) lpg pipe fitting 液化气管件 water seal gate valves 水封闸阀 magnetic co-operate globe valves 磁耦合截止阀 wedge gate valves 楔式闸阀 magnetism forle pumps 磁力泵 y type and cylinder filters y型筒型过滤器 零部件术语 axes guide 轴套 screw 螺栓 ball 球、球芯 sealing 密封件 ball seat 密封圈 spring 弹簧 blowdown sealing face 启、阀件密封面 stem 阀杆 body 阀体 stem mut 阀杆螺母 bonnet 阀盖 stem seal 填料 disc 阀瓣 wedge disc 闸板 mut 螺母 性能术语 applicable media 适用介质 max. discharging capacity 最大排水量 applicable tempure 适用温度 max. operating temperature 最高工作温度 butt clamp 对夹 max. allowable temperature 最高允许温度 chemical anaiysis 化学成份 max. allowable pressure 最高允许压力 connecting format 连接形式 model 型号 double disc 双闸板 name of parts 零件名称 flexible disc 弹性闸板 nominal pressure 公称压力 flange 法兰 outside theread 外螺纹 hoop 卡箍 oxidant 氧化性介质 inside theread 内螺纹 parallet 平行 material chemical analysis and mechanical capacity 材料化学成份和机械性能 reductant 还原性介质 materials 材料 rising stem 明杆 materials for main parts 主要零件材料 seat testing pressure 压力气密封试验压力 mechanical capacity 机械性能 socket 卡套 材料术语 buna-n rubber 丁晴橡胶 high tem perature steel 高温钢 casting aluminium brass 铸铝黄铜 low tem perature steel 低温钢 casting aluminium bronze 铸铝青铜 nylon 尼龙塑料 chr rubber 氯晴橡胶 polytetrafluoroethylene 聚四氟乙烯 chrominm-molybdenum-vanadium steel 铬钼钒钢 pure aluminum 纯铝 chromium stainless steel 铬不锈钢 pure cupper 纯铜 chromium-molybdenum steel 铬钼钢 rubbeer graphite board 橡胶石墨板 corrugation pad 波形垫 spring steel 弹簧钢 cuprum alloy 铜合金 stainless acid-resisting steel 不锈耐酸钢 ductile cast iron 球墨铸铁 stainless and graphite 不锈钢/石墨 expanded graphite 柔性石墨 stainless steel 不锈钢 fine steel casting iron 优质碳素钢 steel casting iron 碳素钢铸件 fluorous rubber 氟橡胶 shell test pressure 壳体试验压力 gray cast iron 灰铸铁 service fluid 工作介质 hayne’s alloy 钴铬钨合金
