1、 HS proposal for plot plan was handed over to Hualu. Comments to plot plan to be given after receipt of flow sheets. 2、 After this date zero date will be agreed upon. 3、 HS will be able to inform finally delivery date after clients approval of the related equipment drawings in the 3 rd lot. 4、 Due to the large number special wishes for the form of the documentation 5、 Documents for both lines are required at this stage. By the agreed time of delivery for each document package HTAS will send by courier service a list of the documents contained in the package with indication of the e- mail issue dates. The courier receipt and copy of the list will be valid for the payment on the L/C. After the last package has been sent HTAS will issue the required hardcopies and CD’s. 6、 Typical drawings of the ammonia converter and loop equipment were reviewed. Hualu had no comments to the drawings. 7、 proposal for plot plan was handed over to Hualu. Comments to plot plan to be given after receipt of flow sheets. The available area available is: Loop 95 x 40 meter, Compressor building: 95 x 24 meter.
