This is especially important around oxygen compressors where location of expansion joints inside the reducers may place them in areas that need to be constructed of velocity exempt materials.
俺来帮大家理解一下什么是velocity exempt materials: 1. 定义:(参见 http:///fileadmin/docs_pubs/doc%2013%2002%20e.pdf ) exempt materials are engineering alloys, which are exempt from any oxygen velocity limitations within defined limits of pressure, material thickness and oxygen purity. only those materials, which demonstrate combustion resistance, when subjected to particle impact and/or promoted ignition tests conducted in oxygen enriched atmospheres can be qualified as exempt. 2. velocity exempt materials = 允许免除氧气流速限制的管材 如果在系统设计压力的条件下,合金材料可以阻燃,就不需要对氧气流速有限制。这种材料就是velocity exempt materials 例子:不锈钢管或铜基合金管 (参考 http:///viewnews.jsp?newsid=4628 和 http:///view/29068a3567ec102de2bd895e.html )
大小头的作用是keep the gas velocity within acceptable levels,大小头两端流体速度有变化,所以需要velocity exempt materials,第二句的主语应该是大小头,大小头附近的区域内要用velocity exempt materials,第三句就是说膨胀节的位置要避开那个区域,要放在流体速度稳定的地方。 不知道我的理解对不对,楼主可以看看大小头和膨胀节附近的材料是否相同。
this is especially important around oxygen compressors where location of expansion joints inside the reducers may place them in areas that need to be constructed of velocity exempt materials. 氧气压缩机周围管线布置中,尤其重要的是异径管之间的膨胀节的位置,可以放置在有流速限制的金属构造(动词)的地方。
this is especially important around oxygen compressors where location of expansion joints inside the reducers may place them in areas that need to be constructed of velocity exempt materials. 在氧压机周围管线布置中,尤其重要的是异径管处的膨胀节可放置在有流速限制的构造材料区域内。
