Based on an estimated pump centerline elevation of 0.7 m and 5.8 m BTL elevation of LP Condensate drum (S05105) from grade. 不知道怎么翻译,是关于泵吸入高度。。。的一个说明
based on an estimated pump centerline elevation of 0.7 m and 5.8 m btl elevation of lp condensate drum (s05105) from grade. 基于预计泵中心线标高为0.7m与 低压疑液罐(s05105)低线标高为5.8 m。 供参考
based on an estimated pump centerline elevation of 0.7 m and 5.8 m btl elevation of lp condensate drum (s05105) from grade. 假定泵中心线标高为0.7米,以此为基准,低压冷凝罐(s05105)底部的标高为5.8米 (btl is bottom line)
