求大神们帮帮忙?
打开总是出现这个东西,大神帮帮忙啊。: DATETIME Fri Mar 17 08:45:00 2017 Failed to initialize the Aspen Properties Enterprise Database. Configuration file can not be found in C:\ProgramData\AspenTech\APED V8.4\config.aem Please use the Aspen Properties Database Configuration Tester to diagnose and fix the problem. 显示全部
,生产管理人员 2018-08-03回答
数据库安装错误,你安装sqr没有?
