Block: HCHANGE2 Model: HEATX * WARNING AT LEAST ONE FEED HAS ZERO FLOW BLOCK BYPASSED Block: REACTOR1 Model: RSTOIC > Loop $OLVER01 Method: WEGSTEIN Iteration 1 * WARNING THE VALUES FOR SOME VARIABLES ARE MISSING. THIS MAY BE CAUSED BY A ZERO-FLOW STREAM. THE PREVIOUS VALUES OF THE VARIABLES WILL BE USED. THE MISSING VARIABLES ARE: "31" THRU "32" 我有物流值为零?我都定义了啊? 14 vars not converged, Max Err/Tol 0.10000E+07
