aspen模拟计算设备时,出现An aspen plus system error has occurred . simulation results can al no longer be loaded interactively . all results will be purged,没有结果,求助改怎么解决? 我已经重装软件还是如此
用 aspen 进行rplug动力学反应的模拟时出现以下错误 error calculations stopped because the maximum number of integration steps has been reached (max-nstep= 1000) 用了百度翻译,显示“由于计算停止的最大数量,整合步骤已经达到(max-nstep = 1000)” 这个到底是什么意思呢,要怎么解决?
aspen模拟计算设备时,出现an aspen plus system error has occurred . simulation results can al no longer be loaded interactively . all results will be purged,没有结果,求助改怎么解决? 我已经重装软件还是如此
