水玻璃,铝酸钠,氢氧化钠合成13X分子筛?
哪位大神有知道 以水玻璃,铝酸钠,氢氧化钠合成13X分子筛,的具体配比,和合成工序那,,求告知!  查了很多文献,都说的很模糊,搞不清楚具体怎样合成!
,机修 2019-11-01回答
你上国际沸石分子筛协会网站,上面有标准配方。这个是协会网站http://www.iza-online.org/
这个是合成配方的网址 http://www.iza-online.org/synthesis/default.htm
FAU
Linde Type X     Si(55), Al(45)
Contributed by Hans Lechert and Philip Staelin
Verified by D. Ginter, by E. Basaldella, and by E. Fallabella Sousa-Aguiar
Type Material Na86Al86Si106O384 : wH2O (w ~ 260)
Method H. Lechert, H. Kacirek
Batch Composition NaAlO2 : 4 SiO2 : 16 NaOH : 325 H2Oa,b
Source Materials
distilled water
sodium hydroxide (99+% NaOH)
alumina trihydrate (Merck, 65% Al2O3) c
sodium silicate solution (27.35% SiO2, 8.30% Na2O, 1.37 g/mL)
Batch Preparation (for 42 g product)
(1)        , stir until dissolved
(2)        , stir at 100¡C until dissolved, cool to 25¡C
(3)        , mix
(4)        , mix until dissolved
(5)        , mix until dissolved
(7)        , combine quickly and stir for 30 minutesd
Crystallization
Vessel:        polyethylene bottles
Temperature: 90¡C
Time: 8 hours
Agitation: none
Product Recovery
(1)        Filter and wash to pH < 10
(2)        Dry at 1000C, equilibrate over saturated aqueous NaCl
(3)        Yield: near 100% on Al2O3
Product Characterization
XRD 100% FAU, a0 = 24.92 Å, competing phases: LTA, GIS, ANA, SOD
Elemental Analysis: NaAlO2. 1.24 SiO2f
Crystal Size and Habit: spherical aggregates, 0.8 um dia.
,销售 2019-11-01回答
万分感谢!
