What is the synthesis method o...
What is the synthesis method of 2-phenyl-2-propanol?
,销售 2024-06-23回答
2-Phenyl-2-propanol is an important raw material for the synthesis of diisopropylbenzene peroxide (DCP), which belongs to alcohol derivatives.
2-Phenyl-2-propanol
Characteristics
2-Phenyl-2-propanol is a white to pale yellow, odorless solid. It is flammable but difficult to ignite under normal conditions, and almost insoluble in water.
Applications
2-Phenyl-2-propanol can be used in organic synthesis, as well as in the fields of pesticides, pharmaceuticals, and dyes as reactants or intermediates.
2-Phenyl-2-propanol is the main metabolite of diisopropylbenzene, making it a biomarker for diisopropylbenzene.
Reasons for restriction
Currently, there are no legal regulations on this chemical in finished products, but multiple brands' RSL and AFIRM RSL list it as a restricted chemical.
The German Federal Institute for Risk Assessment (BfR) comments that 2-Phenyl-2-propanol may cause allergic reactions.
Synthesis method
One industrial method for synthesizing 2-Phenyl-2-propanol involves the reaction of water-soluble sulfide MxS with diisopropylbenzene peroxide, where M represents H, Li, Na, K, Ca, Mg, or NH4 +. The amount of MxS used is 200% of the theoretical amount determined by the reaction equation, with a reaction temperature of 0-150°C and a reaction time of 0.5-8 hours. After the reaction, the layers are separated, the lower aqueous phase is removed, and the organic phase is washed with water until the pH of the water phase is 6-8 to obtain the product.
国内供应商(104家)更多>
