aspen plus系统出错,怎么解决,各位朋友,急!?
*****SYSTEM ERROR END OF FILE REACHED WITHOUT CLOSING SINGLE QUOTE. ************************************************************** * EROR SEVERITY LEVEL OF -1 IS <=ABORT LEVEL OF 0 * * EXECUTION IS TEMINATED:SIMULATION WILL NOT BE EXECUTED * ************************************************************** Error while processing input specifications simulation failed because of a Fortran or internal Aspen Plus error.The simulation cannot continue.Contact the AspenTech hotline for assistance.The error log file can help the hotline diagnose the problem,Create error log file MMSYS.ERR? 显示全部
,化工研发 2018-05-24回答
也是遇到这个问题了 你后来解决了吗?
,化工研发 2018-05-24回答
也是遇到这个问题了 你后来解决了吗?
