跪求懂.cif的同学老师帮助啊?
各位哥哥姐姐同学老师,跪求大家来看看这个,急需埃洛石HNTs的.cif文件,找了很久这边有一个之前前辈的回答,我将回答粘贴到下面,原作者说将下面回答粘贴复制到文本改后缀就可以,但我根据人家的回答做出来不对啊,希望懂的人能帮我看看哪有问题啊???谢谢大家了,真的急需,麻烦您了啊!!!
*data for   ICSD #26716
Coll Code   26716
Rec  Date   1980/1/1/星期二
Mod  Date   2007/8/1/星期三
Chem Name   Dialuminium Disilicon Trioxide Octahydroxide
Structured  Al2 Si2 O3 (O H)8
Sum         H8 Al2 O11 Si2
ANX         A2B2X11
Min Name    Halloysite
D(calc)     2.09
Title       Ueber die Struktur von Halloysit und Metahalloysit.
Author(s)   Mehmel, M.
Reference   Zeitschrift fuer Kristallographie, Kristallgeometrie, Kristallphysik, Kristallchemie (-144,1977)
            (1935), 90, 35-43
Unit Cell   5.2 8.92 10.25 90. 100. 90.
Vol         468.21
Z           2
Space Group C 1 m 1
SG Number   8
Cryst Sys   monoclinic
Pearson     mS46
Wyckoff     b6 a3
Red Cell    C  5.162 5.162 10.25 95.017 95.017 119.519 234.107
Trans Red   0.500 -0.500 0.000 / 0.500 0.500 0.000 / 0.000 0.000 1.000
Comments    With Si2 O3 (O H)2- and Al2 (O H)6-sheets, wrong structure
            Compound with mineral name: Halloysite
            The structure has been assigned a PDF number (calculated
            powder diffraction data): 01-074-1022
            The structure has been assigned a PDF number (experimental
            powder diffraction data): 29-1489
            Standard deviation missing in cell constants
            X-ray diffraction (powder)
            Unusual difference between calculated and measured density
            No R value given in the paper.
            At least one temperature factor missing in the paper.
            Coordinates are those given in the paper but are obviously
            wrong.
            Position of 16 Elements of H Are Undetermined.
Atom  #   OX   SITE      x           y           z           SOF      H
Al   1  +3    4 b   0.25        0.167       0              1.         0
Si   1  +4    4 b   0.008       0.167       -.444          1.         0
O    1  -2    4 b   -.046       -.167       0.118          1.         H1
O    2  -2    2 a   -.046       0           0.118          1.         H1
O    3  -2    4 b   -.046       0.333       0.397          1.         H1
O    4  -2    4 b   -.046       -.167       -.118          1.         H1
O    5  -2    2 a   -.046       0           -.118          1.         H1
O    6  -2    2 a   0.283       0           -.375          1.         0
O    7  -2    4 b   0.033       0.25        -.375          1.         0
Std. Notes  Transformation Method: Tidy
            TRANS  Origin  .95400 0 .88200
Std. Cell   5.2000 8.9200 10.2500 90 100.000 90
Std. Vol.   468.21
Std. Z      2
Std. SG     C1M1
Std. Atom
Al   1  +3    4 b   .29600      .16700      .11800         1.
Si   1  +4    4 b   .05400      .16700      .67400         1.
O    1  -2    4 b   .00000      .16700      .23600         1.
O    2  -2    2 a   .00000      0           .23600         1.
O    3  -2    4 b   .00000      .33300      .51500         1.
O    4  -2    4 b   .00000      .16700      .00000         1.
O    5  -2    2 a   .00000      0           .00000         1.
O    6  -2    2 a   .32900      0           .74300         1.
O    7  -2    4 b   .07900      .25000      .74300         1.
*end for    ICSD #26716 显示全部
3人参与回答
,化工研发 2019-08-08回答
我给你找了个26716的cif文件。希望能够帮到你
,设备工程师 2019-08-08回答
我这边还有两个HNTs的卡片,希望懂的大佬前来指点啊 Card Information Names: Aluminum Silicate Hydroxide Halloysite-7A metahalloysite Formula: Al2 Si2 O5 ( ...
,销售 2019-08-08回答
看看是不是这个
http://www.crystallography.net/cod/1011246.html
