What is Zytel® HTN?
东莞市广裕塑胶原料有限公司
东莞市广裕塑胶原料有限公司 进入商铺
3人参与回答
,暂无简介 2026-07-24回答
What is Zytel® HTN?
Zytel® HTN is a range of materials based on polyphthalamide semi-aromatic nylons. Even more than standard polyamide resins, the HTN range offers especially high strength and stiffness over a wide range of temperatures, chemicals and moisture exposure.  Zytel® HTN has excellent dimensional stability and flow, enabling efficient processing of even complex parts. This range of materials is widely used to replace metal parts that must withstand high temperature tolerances (such as engine cooling, handheld devices and non-halogenated connectors), while reducing cost and weight.
Zytel® HTN 是一类基于聚邻苯二甲酰胺半芳香族尼龙的材料。与标准聚酰胺树脂相比,HTN 系列在更宽的温度、化学品和潮湿环境条件下,表现出尤为出色的高强度和高刚性。Zytel® HTN 具有优异的尺寸稳定性和流动性,即使是复杂部件也能实现高效加工。该系列材料广泛应用于替代必须承受高温耐受性(如发动机冷却系统、手持设备和无卤连接器)的金属部件,同时降低成本和减轻重量
