业界开出氟化工转型升级“处方”? 7个回答.3人已关注
“同样是氟化乙烯丙烯共聚物(fep)产品,国内企业生产的产品价格为8万元/吨,而跨国公司可以卖到20万元/吨以上,其中的差别可能就在一个技...
爱你不过三个 ,设备维修 2018-08-03回答
“同样是氟化乙烯丙烯共聚物(fep)产品,国内企业生产的产品价格为8万元/吨,而跨国公司可以卖到20万元/吨以上,其中的差别可能就在一个技术小窍门。如果氟化工产业能苦练内功,攻克这些小窍门,对提升现有产品质量、提高产品附加值和利润率无疑大有裨益。” 其中的差别不是技术窍门之类的, 价格的差异是因为功能差异造成的, 但如何发现客户对功能的需求, 是产生产品附加值的根本。 跟在跨国公司后面学, 短期内可行, 长期是不行的, 你学我也学, 之后还是产品同质化, 然后就是价格战。 作为用户一方也是有意来加速产品同质化的进程。
多晶硅价格有周上涨5.38%,大家怎么看? 7个回答.1人已关注
种草莓的小仙 ,高级研发工程师 2018-08-03回答
只是开始哦,之后一定还有一段上涨的空间,立帖为证!呵呵 看来你的信心这么强哦,但愿吧
分子筛结构(外文的,带图)? 2个回答.2人已关注
lz的附件: 只是不能显示图形。 分子筛的结构 zeolite - structure and properties zeolite molecular sieves are crystalline, highly po...
是妳 ,销售 2018-08-03回答
lz的附件: 只是不能显示图形。 分子筛的结构 zeolite - structure and properties zeolite molecular sieves are crystalline, highly porous materials, which belong to the class of aluminosilicates. these crystals are characterised by a three-dimensional pore system, with pores of precisely defined diameter. the corresponding crystallographic structure is formed by tetrahedras of (alo4) and (sio4). these tetrahedras are the basic building blocks for various zeolite structures, such as zeolites a and x, the most common commercial adsorbents. molecular sieve type a molecular sieve type x due to the presence of alumina, zeolites exhibit a negatively charged framework, which is counter-balanced by positive cations resulting in a strong electrostatic field on the internal surface. these cations can be exchanged to fine-tune the pore size or the adsorption characteristics. for instance, the sodium form of zeolite a has a pore opening of approximately 4 ångstrom (4 x 10–10 m), called 4a molecular sieve. if the sodium ion is exchanged with the larger potassium ion, the pore opening is reduced to approximately 3 ångstrom (3a molecular sieve). on ion exchange with calcium, one calcium ion replaces two sodium ions. thus, the pore opening increases to approximately 5 ångstrom (5a molecular sieve). ion exchange with other cations is sometimes used for particular separation purposes. molecular sieve 4å ion exchangge molecular sieve 3å the pore opening of the sodium form of zeolite x (13x) is approximately 8 ångstrom. the ability to adjust the pores to precisely determined uniform openings allows for molecules smaller than its pore diameter to be adsorbed whilst excluding larger molecules, hence the name “molecular sieve”. the different pore sizes of synthetic zeolites open up a wide range of possibilities in terms of "sieving" molecules of different size or shape from gases and liquids. selective adsorption of water and other polar substances the up-take of water or other species in zeolites is called adsorption and functions on the basis of physisorption. the main driving force for adsorption is the highly polar surface within the pores. this unique characteristic distinguishes zeolites from other commercially available adsorbents, enabling an extremely high adsorption capacity for water and other polar components even at very low concentrations. in addition, the pore size plays a significant role, allowing or prohibiting the entrance of molecules to the pore system. the adsorption on molecular sieves is therefore dependent on the following physical molecular properties: size and shape: molecules larger than the pore opening of the molecular sieve can not be adsorbed, smaller molecules can. molecular polarity: molecules with large polarity or polarisability can be adsorbed preferentially under identical conditions.
低温甲醇洗的循环甲醇泵的设计压力? 2个回答.1人已关注
我家男神最呆 ,化工研发 2018-08-03回答
泵没有所谓的设计压力,专业一点的说法是最高允许工作压力,一台泵的最高允许工作压力通常为最高入口压力+关死杨程点压力x110%
硫铁矿制硫酸余热锅炉? 1个回答.3人已关注
奶气 ,研发工程师 2018-08-03回答
南京海陆:硫酸余热锅炉专家。顺便说一下,卧式的比较好,希望对你有帮助。
汽轮机凝汽器泄漏? 8个回答.4人已关注
时岫 ,给排水工程师 2018-08-03回答
我们单位汽轮机凝汽器管子出现过漏的情况,查漏采用壳层充满水静压试验方法,进行查漏,对漏的管子采取了铝堵头两侧堵塞方法进行处理,堵塞管子数量不超过总管子10%,目前通过对凝汽器排出的凝结水硬度检验,符合使用要求。
求字体2款? 7个回答.3人已关注
素水。 ,销售 2018-08-03回答
原帖由 ps122hb 于 2008-9-9 08:08 发表 scidi不是上海化工院吗?,这个字体没有,用别的字体替换不行? 别的我都有啊,也试着用g开头的一个字体替换,可是还是有乱码
封头组对照片? 8个回答.1人已关注
昙花朝拾 ,设备维修 2018-08-03回答
一楼的什么意思呢?是不是对封头的组对不满意呀? 问题有几个:1、错边量大 2、封头的表面质量较差,脏 3、纵缝坡口质量差 4、组对缝隙不均匀。 不知道说的对不对?
宁东煤化工项目建设情况? 5个回答.3人已关注
宁煤的甲醇投产,烯烃,二甲醚进入尾声,甲醛,煤制油马上开始;宝丰的焦化1、2号炉投产,3、4号马上投,甲醇正在安装;宝塔的没实质性进...
wul小仙女 ,设备工程师 2018-08-03回答
宁煤的甲醇投产,烯烃,二甲醚进入尾声,甲醛,煤制油马上开始;宝丰的焦化1、2号炉投产,3、4号马上投,甲醇正在安装;宝塔的没实质性进展,光圈了地;盛大的二甲醚扯了,由于资源问题;川化的尿素正在三通一平;国电英力特的前段时间开始建了,华能的焦化已经批复,正在建设煤矿;中电投的正在建设煤矿,煤化工产业正在批复;中盐的只有个规划,没有进展。
锅炉辅机厂家? 3个回答.2人已关注
小胖仙 ,化工设备专员 2018-08-03回答
减温减压器:江苏宇达电站辅机阀门制造有限公司 除尘器:河北慧宇环保设备有限公司 排污冷却器:青岛同方热电设备有限公司
7k关注者
4k关注者
4k关注者
62w回答
176关注者
