就是盐酸和氧化铝、氧化铁反应。 ->processing input specifications ... information pure component parameters for some components are retrieved from sdf table. these parameters are used with the elecnrtl option set unless you enter your own parameters in prop-data paragraphs parameters retrieved for component hcl are: cpdiec plxant parameters retrieved for component h2o are: vlbroc plxant ** error hypothetical liquid component hcl cannot be processed because there are no solid data--cpsxp1 is missing mw available for component tio2 is different from mw calculated from formula (atomno/noatom). calculated value is used. available mw = 79.86580 calculated mw = 79.87880 * warning in physical property system parameter dhform/element 1 (data set 1) upper bound violated for component fe+3 value = 0.57128e+10, upper bound = 0.50000e+10 * warning in physical property system parameter dhform/element 1 (data set 1) upper bound violated for component al+3 value = 0.54832e+10, upper bound = 0.50000e+10 * warning in the "stream" paragraph which begins on line 125 stream name: 1 component mass fractions are normalized to unity. * warning in the "stream" paragraph which begins on line 129 stream name: 2 component mass fractions are normalized to unity. * warning while checking input specifications block name: b5 model name: rstoic no combustion reactions are possible - oxygen (o2) has not been defined as a component. ! errors while processing input specifications
