大佬们好,v11到v12后换热器一直报错怎么解决呢?
在一个电脑上v11正常,但在v12的电脑上打开bkp文件之后就一直鼓掌
The following Unit Operation blocks were
completed with errors:
B5
*  WARNING IN PHYSICAL PROPERTY SYSTEM
   PARAMETER PLXANT (DATA SET 1) FOR COMPONENT H2O2:
   UNREASONABLE VAPOR PRESSURE CALCULATED AT NORMAL BOILING POINT.
,化工人一枚 2023-09-26回答
估计是物性方法不对。还有H2O2侧的物性参数缺失
