Check that your Proces condtions are physically possible
it may help if you remove or relax any design constraints you have imposed
Failing this, changing from the Standard to the Advanced Method may help.
Alternatively, try changing the side to which the hot stream is allocated
数据表里蒸汽密度为0,但是曲线有,这个应该怎么解决,方法是选用advanced
