苯基三氟甲烷磺酸酯,也被称为三氟甲磺酸苯酯,是一种常用于有机合成的化合物。它可以通过苯酚酰化反应来制备。
制备苯基三氟甲烷磺酸酯的方法如下:在0℃和氩气保护下,将三氟甲磺酸酐(10g,35mmol)滴加到苯酚(3.16g,35mmol)的吡啶(60mL)溶液中。将混合物在低于5℃的条件下搅拌24小时,然后将其倒入乙醚(100mL)中并用水(3×60mL)洗涤。将有机部分干燥(MgSO4)并减压蒸发,得到苯基三氟甲磺酸酯(0.93g,77%收率)。1H NMR (CDCl3, 400 MHz): δ 7.24-7.26 (2H, m), 7.35-7.36 (1H, m), 7.39-7.43 (2H, m). 13C NMR (CDCl3, 100 MHz): δ 114.1-126.6 (CF3, q, J = 310 Hz), 121.3, 128.4, 130.3, 149.7。
另外,苯基三氟甲烷磺酸酯也可以通过4-碘三氟甲磺酸苯酯在醋酸钯催化下制备得到。
苯基三氟甲烷磺酸酯可以用于制备(S)-2-苯基丙酸叔丁酯。
[1] Sabin, Margaret V . Synthetic studies on two silicon assisted annulation reactions.[J]. Aiche Journal, 1994, 55(55):594-611.
[2] Zhu S , Wang C , Chen L , et al. Modular Approach for Synthesis of Vicinal Diamines Containing Axial Chiral 1,1'-Binaphthyl from 1,2-Diaminoethane by Pd-Catalyzed N-Arylation Reactions[J]. Organic Letters, 2011, 13(5):1146-1149.
[3] Chu Q , Brahmi M M , Solovyev A , et al. Ionic and Organometallic Reductions with N-Heterocyclic Carbene Boranes[J]. Chemistry, 2009, 15(47):12937-12940.
[4] (US20150166586) Chiral phosphines for palladium-catalyzed asymmetric α-arylation of ester enolates to produce tertiary stereocenters in high enantioselectivity
